IBM IMM Help.
I have RDM set to connect a sonicwall VPN then open
http://192.168.51.16:8081/page/login.html
when i press the login button i get the below Script Error message.
if i go to http://192.168.51.16:8081 it does not autofill the login details but it lets me connect.??
Script Error.
line:44
char:9
error:"txtusername" is underfined
code:0
URL:http://192.168.51.16:8081/impl/login_imp.js
Many Thanks James.
Think i may have it :)
What was the problem?
so the default webpage is 192.168.16.201:8080/# however the login will not discover, so i had to use 192.168.16.201:8080/page/login.html found this by right clicking the default webpage and going to properties
but by using 192.168.16.201:8080/page/login.html it gave the error so i changed it back to 192.168.16.201:8080/# this way the autofill works.
only thing i cant get working is the [submit]
edited by Jamesdyke on 5/30/2012
