Problems with Group permissions !!!!!!
Hi I am currenlty useing a site licence of enterprise edition with SQL datasource
when I add a groups\folders and apply security other groups\folders with similar names are also affected
e.g
Production (This group is not visable to normal users and is assoicated with the "production" group)
Production Services (This group is avilable to all user and is assicated with a group called "productionSvc")
Production Services is not visable until I rename it to something other then Production Services e.g "ZProduction Services" or "test Services"
Production-Services does work nor does Production-Services
Also I have notice whne applying permission you can not grant the same user different rights within different group ?
Both of these bugs are pritty serious if you anat to sell this as an enterprise product can you please resolve as soon as possible
Thanks You
It's the first time someone report me this bug. I have entered a bug request. For the second one, could you explain it to me with an example?
I tried to reproduce but I'm unable. It's a little bit confusing because you use group for both. Could you use "security group" and folder instead? Is it when you rename the folder that the bug disapears?
I think that I've found the problem. I've made a fix. Could you try this version?
http://remotedesktopmanager.com/download/Setup.RemoteDesktopManager.7.1.1.0.exe
