x86 and x64 versions
We have been using your software and it great.
One problem we have with it is that it comes only in one flavor(x86) but all of our other software are x64.
This is causing some problems with VPN and other apps we are using such as ThinPrint.
Is it on your road map to release 64 bit version any time soon.
Valdi Hafdal
All Comments (4)
The problem is that most of the integrated technology we use does not support x64 because it's COM based. I will verify if we could create two separate build of our product. Thank you
have you tried this?
http://chrizyuen.wordpress.com/2011/04/07/usage-for-corflags-exe/
Hi, i have not tried this but this hardly seem like an option if i want to deploy the software on 30 machines and when when reinstalling machines for our employee´s that i have to do this after i deploy RDM.
You can do it once and zip it. I will try on my side but I can't give you a time frame.
