PPTP connection - how ?
Probably one stupid question from the newbie :)
I am trying to set up VPN session for the following credentials and no luck...
I've tried each of VPN connection types available in Remote Desktop Manager and neither one seems to be the match for that and neither one works...
No problems connecting to same VPN from Windows (Network and Sharing Center from Control Panel).
How do I do it in RDM?
VPN Server IP: XXX.XXX.XXX.XXX
VPN User: XXXX
VPN Password: XXXX
VPN Type: PPTP
All Comments (1)
It's the Microsoft VPN. Perhaps you need to check "Use rasphone (Connection Manager Kit)"
