MS Surface pro (2 or 3)
Wondering if anyone has been able to run RDM on the surface pro, or not been able to for that matter?
I currently own the Surface 2 and it will not run but that is because it uses Window RT.
The Pro line uses Windows 8.1 and has an I3/I5/(now it is even available in an I7) but before spending the cash on the pro I would like to be sure it will work.
All Comments (1)
I run PVM (at home for personal use) on my Surface Pro (original). I have had no issues.
Here at work, Max our marketing director runs RDM on his Surface Pro 3 and all is good.
As you stated it requires the Pro (Windows 8.1) not the other (Windows RT) version.
Best regards
Stéfane Lavergne
