Can't mark Roles for Users - Interface Problems?
Hello together,
I have a problem when i try to mark a role for an User.
When i choose an User and click on Roles, i can't mark these Roles(as you can see on picture 3)
Normally it looks like picture 1 ( screenshot from antoher Client).
For me it seems like an Interface Problem because a few thinks didn't look normal.
For Example: When I start the Programm I see the RDM Logo and Version, but the Window is cut off (picture 4)
Or on Picture 2 the "offline mode" overlays "Read-only"
Can you tell me how i can fix this?
Thank you and Best Regards,
Alex
edited by akopatz on 11/18/2014
Do you have large font enabled in Windows? It might be causing sizing issues with the UI. We will have a look.
Stéfane Lavergne
Thank you for the fast answer.
You are right, the font is on 125% because the User has a very high resolution.
It works without any Problems on 100%
Is there a fix to use the RDM on 125%?
Thanks,
Alex
We will need to look at what we can do, for now 100% is your only option. I've added it to our to-do list.
Stéfane Lavergne
