Telnet for HP ProCurve Switches
If I connect to HP ProCurve Switches via telnet, most of the lines are blank. If I resize the window the content appears. I have tested other terminal settings (Auto wrap off/dos) but without success. Does anybody know a configuration of telnet sessions in RDM which will work like they do in regular windows terminal windows?
Thanks a lot
Flotto
All Comments (4)
Do you use Putty or the native Telnet?
native telnet
saw this last week for first time, I think you need to check "Implicit carriage return on line feed" or one of those terminal settings to solve this.
It is "Implicit carriage return on line feed". Thanks for your solution.
But how can I batch edit this for all my sessions? Batch edit is not supported for any type of session...
edited by Flotto on 11/12/2014
