Virtual Box Session won't launch in embedded mode
Under newly installed version 10, when a VBox session is launched with the embedded (tabbed) selection it opens in a normal virtual box session and not inside of RDM.
All Comments (1)
Are you sure it was working with the previous version? I don't remember to have integrated it in embedded mode. Could it be possible that's because you now use the 64 bit version of virtual box?
