Not keeping window sizing using MainFormMinimal*
Using the MainFormMinimalHeight and MainFormMinimalWidth config options and only showing the navigation frame, upon restart, the main window doesn't remember its size from when it was last closed.
To reproduce:
Add:
<MainFormMinimalHeight>50</MainFormMinimalHeight>
<MainFormMinimalWidth>50</MainFormMinimalWidth>
Turn off all layout features except navigation and resize the window down to something small.
Restart the application and I get this:
Ideally, it would retain the width that I set it too before I closed it last.
I will verify. I suspect that we have a minimal size that reset your settings
This is now fixed internally and it will be in the next beta release.
Awesome. Thank you.
