Install on systems with less memory than 512 MB
I use a VPC for sessions with exotic VPN'S. The VPC is running WinXP with 128 MB memory. If I want to install my newest RDM Version 7.0.4 on the VPC I got the Message: "Cannot be installed on systems with less physical memory than 512 MB." I know that earlier Versions of RDM permitted the Installation on this machine. How can I use RDM on my VPC?
All Comments (2)
This is a limitation only in the installer. Download the zip file instead and the application will start.
Thanks. It worked fine.
