@ sign and RDP connection issues
Hi there,
since previous version of rdm (i don't know which version exactly, maybe version 9 and above) if have to problems and i think both of them are bugs.
First problem is when i'm working on customers server and switch between my two monitors i can't make an @ - sign with AltGr and Q, i only can make the sign with strg+alt and Q. It sucks. And i noticed the problem only with rdm, never ever with other applications.
Second problem is since upgrading to version 10.0.3.0, when i connect with rdp to customers server (even when i conncet only to one server or to 20 server at the same time), first of all i got the rdp connection timeout window. But i'm already connected to the server, but when i switch between some tabs i got this message. I think it occurs when i connect first time in the morning to about 10-20 servers at the same time and then switch from one tab to another tab.
I'm using Win 8.1 x64 with latest updates.
kind regards
All Comments (4)
For the keystroke problem it could depend where the focus is. Does it work when you focus the quick connect? For the other issue it's because of the sizing mode. You can go in File->Options | Types -> RDP and set the sizing mode to none. When you see the reconnect dialog it's because the application is adapting the resolution when the window size change. Unfortunately the Microsoft Active X shows a reconnect dialog and there is nothing we can do for that.
hi david
Ok at next time i'll try it. Actually the sign works.
I set now the sizing auf none. Next time i'll test it again and see how it works.
thx for your quick response
Setting connection properties display to smart size also prevents the reconnects..
Hm, my settings weren't saved during last changes. I'll check it tomorrow. But one thing i don't really understand, why is this only after update to the newest version? I don't have this issues with the previous version.
