Hi
I wanted to connect a server with SonicWall NetExtender VPN:
When I connect I only get a blackscreen:
And my workstations (win 7 x64) network environment hangs:
Then I have to restart / logoff my session to solve it.
Did RDM got some problemes connecting with NetExtender?
Version:
Client Win 7 x64 sp1
RDM 7.0.4.0
SonicWall NetExtender 4.0.138
RDM SonicWall NetExtender Plugin 1.9.2.0
edited by imation on 4/12/2012
As far as I know this add-on is functional. Could you try to execute RDM with Run As Administrator to see if this help?
no same behavior
Could you try the command line directly?
netcli connect -s MyServer -u MyUser -p MyPassword -d MyDomain
Solution found, I've installed NetExtender Version 5.5 ... now it works!
Great. What version were you using before?
As I wrote in my first post V. 4.0.138
Oups! Sorry I've missed it.
np =)
