HP System management homepages
We use HP System Insight Manager (SIM) and I have created tabbed sessions in Remote Desktop Manager to access SIM. That works fine but when I have an alert I can not get to the system management homepage of the client with the alert. I think it's a problem with the self signed certificates the the servers have. I have tried both IE and FireFox with the same result. Adding the all to the root trusted store would be problematic as I manage just over 4000 servers. Any ideas I can try?
Thank you,
Tom
Thanks,
Tom
All Comments (2)
Could send me the message you received exactly? I will do some search about it and come back to you.
I am getting the "There is a problem with this website's security certificate" in IE. When I select "Continue to this website (not recommended)." it puts me right back to "There is a problem with this website's security certificate". I can't figure out why.
Thanks,
Tom
