I would like to have a revising function in RDM. It would be sufficient to set a responsible RDM user and a revising period for example. I need it both on a session/credentials level and at folder level.
Perhaps a setting to be able to inherit revising settings from parent folder to a session/entry. It could be that one RDM user is responsible for all sessions/credentials within a folder, but also that we have a mix of responsible persons within a folder.
Best Regards,
Ola
This feature should be coming in the next major release. It was cut for the version 7.0 but it's planed.
Excellent! Thank you for your quick reply!
Is there a release date set for next major release?
Unfortunately it's only this summer. We will have multiple small releases coming in the next month but the next big one is more in July /August
Is this implemented in 7.5? Where can I find documentation on how to use the revising functions?
It not exactly inherited as a checkbox but it's by using the parent variable. We will have more documentation coming soon. You can define a site or a device and use the variable from them.
