SQLNCLI provider not registered on local machine
Hello - recently we purchased the Enterprise edition of RDP Manager - previously had been using as standard - I have upgraded to Enterprise on a couple of machines and connected to the SQL DB no troubles. But on a new laptop I have and on a colleagues XP machine we have had some troubles when trying to connect to the SQL DB - the error we are receiving is:
The current datasource is unavailable.
The 'SQLNCLI' provider is not registered on the local machine.
I am running Vista Home Premium x64 on the laptop w 5.5.1.0 DevolutionsRDP Manager in Enterprise Edition on 1 machine that I am getting this error. (This is almost exactly the same config as the desktop I have no trouble connecting with)
The other is running XP.
Thanks for any help here. I am not sure what I am missing.
All Comments (13)
I think that Microsoft SQL Server Native Client (64 bits) is not installed on your PC.
http://download.microsoft.com/download/2/7/c/27c60d49-6dbe-423e-9a9e-1c873f269484/sqlncli_x64.msi
For the 32 bits version
http://download.microsoft.com/download/2/7/c/27c60d49-6dbe-423e-9a9e-1c873f269484/sqlncli.msi
http://remotedesktopmanager.com/remotedesktopmanager/Home.aspx/Download
Can you try this ?
Devolutions inc.
Thanks - that worked!
I will keep those links for future
I installed SQL 2008 Express with tools onto my Windows 7 32bit laptop about 3 weeks ago using the download from the Microsoft site; I believe this includes the most recent service pack for SQL Server 2008. I subsequently tried to install RDM to my laptop and connect to our central SQL Server database but I get the message that the SQLNCLI provider is not registered on my machine. I cannot install the provider from the links provided on your site, since I have a newer version installed (according to the installation error message). I found a link to a more recent version here: http://www.microsoft.com/downloads/details.aspx?familyid=B33D2C78-1059-4CE2-B80D-2343C099BCB4&displaylang=en but I can only repair or remove the SQLNCLI provider using that installer - I already have it installed. I have RDM version 5.6.3 enterprise licence (I reinstalled just now in case I had an out of date version but the error persists).
Any ideas? I am able to open SQL Management Studio and connect to the database from my laptop directly, just not through RDM.
Can you check in the application log if you see an error message. It's located in the menu Help.
Let me know
Devolutions inc.
Hi again,
Can you try to install the SQL Server Native Client:
http://go.microsoft.com/fwlink/?LinkId=123717&clcid=0x409
Devolutions inc.
From Application error log:
ERROR[30/10/2009 11:38] System.InvalidOperationException: The 'SQLNCLI' provider is not registered on the local machine.
at System.Data.OleDb.OleDbServicesWrapper.GetDataSource(OleDbConnectionString constr, DataSourceWrapper& datasrcWrapper)
at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection)
at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup)
at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
at System.Data.OleDb.OleDbConnection.Open()
at Devolutions.RemoteDesktopManager.Business.DataSources.SQLServerConnectionDataSource.FetchVersion()
at Devolutions.RemoteDesktopManager.Business.DataSources.SQLServerConnectionDataSource.get_Version()
at Devolutions.RemoteDesktopManager.Business.DataSources.DatabaseConnectionDataSource.get_IsUpgradeRequired()
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.get_IsUpgradeRequired()
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.Upgrade()
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.LoadConnectionsFromDatabase(BaseConnectionDataSource aConnectionDataSource)
I just tried the provided link to install the native client, but I get the message that a higher version is already installed, and I have to uninstall that before I can continue. I can try that if all else fails, but have been hesitant to do so in case of breakage elsewhere with SQL Server...
Can you try a repair before the uninstall ?
Devolutions inc.
Did that already - same result sadly... since this isn't my main dev box, I'll try the uninstall, install the older version, try connecting, then try installing newer version over the top and see if things still work - I'll keep you posted :)
Can you try something stupid for me, install the native client for SQL Server 2005, maybe there some dll not included in the one for SQL Serer 2008. That's the kind of think microsoft does.
Let me know.
Devolutions inc.
Can you try this special build before you uninstall?
http://remotedesktopmanager.com/download/Devolutions.RemoteDesktopManager.Bin.5.6.3.2.zip
Devolutions inc.
Special build seemed to work! I got the message "Database Upgrade Successful" and now see my connections listed :)
Good,
Microsoft removed a driver, I changed the driver. You can keep this version until I do an official build. Anyway in the next major update, the SQL Native Client won't be needed anymore.
Thank you for your help
Devolutions inc.
Excellent work - many thanks again for the speedy replies - RDM is an essential part of our business, we absolutely rely on it to manage all our servers - fantastic product!
