Psexec and share folders problem
Hi
Psexec is one of your best feature (remote command prompt)
you can remote to computer via credential
but the credential of remote session does't work on psexec and share folder
All Comments (4)
I'm not sure, but it's possible that we have fixed a bug related to that in the new version 7.0 just released.
if you want I can share screenshots
for servers that in my domain (same credentials) I haven't got any problem
in some cases you're right
but in some servers if they was in other domain they want username and password
but i remote to server without problem
edited by alireza1023 on 2/29/2012
Have you tried to set the credentials in the Tools section of the session configuration?
custom credentials solved share folder problem
but psexec problem didn't solved yet
Ends in 7 days
