mRemoteNG Import Help
Hey guys, we're trialing the software at our work and currently use mRemoteNG. I have an password protected XML configuration (confCons.xml) and that fails to import. Expecting this result I went ahead and just removed the password protection on the group, saved and went to import with the mRemote profile and it fails.
Any thoughts? Heres a snipet of the error I receive:
Could you send me (via private message or email slavergne-at-devolutions-dot-net) the top 10 or so lines of the file.
Please make sure to sanitized the data so that no sensitive information is present in the file.
Stéfane Lavergne
It appears that even though I turned off password protect on my mRemoteNG application, it is keeping the xml data encrypted. I'm going to keep looking at this and will get back to you guys afterwords. Thanks for the follow up Stefane, it made me look at the xml data to see what was actually breaking the import call.
No problem, keep me posted.
Stéfane Lavergne
Closed
