Ctrl+Shift+[Left Arrow OR Right Arrow] issue
Hi Devolutions!
When I'm in a remote session, and I hit Ctrl+Shift+[Left Arrow OR Right Arrow], it toggles the session I'm pointing to. How do I turn this feature off and present the keystroke to the session?
Background: Ctrl+Shift+[Left Arrow OR Right Arrow] is the 'word-break highlight' function with windows (try it).
I use this keystroke every 10 minutes, and its really interfering with my ability to use RDM.
Thanks in advance!
You can change the shortcut in File->Options | User Interface - Keyboard
SWEET! THANKS!
I'd like to add a remark to this issue.
When starting a remote session and switching to another application before the tab is created, the Ctrl-Shift-[Left/Right] hotkey is somehow globally registered in my host session.
That means that when using this hotkey in e.g. Word, RDM will change the active tab in the background.
The solution is to activate RDM and after leaving, the hotkey is properly deregistered.
