I he created s server object, and assing into a set of connections with different security gropus definitions each one. I save the object as template. When I use the saved template to deploy new server objects, the security configuration is set to none. If I like to obtain the defined security groups, I've to clone the original entry.
Was it a shared or a local template? The local template can't save the security since it's global and it's not specific to a data source.
Shared. Tested again with 9.4.11. Security to "none"
Any news? Important concern in the project I'm working on...
I can't reproduce it. What data source type do you use?
SQL Server.
Now seems to work on 9.4.12.0
Thanks!!
