I can't seem to find the setting that is making this happen. When opening a session now, it removes my Navigation, even though I have it set to docked.
I made a quick gif of what I'm referring to: http://i.imgur.com/4VuxkVA.gif
(I'm running RDM v9.4.7.0 on Win 8.1)
edited by johndoe5 on 7/25/2014
Make sure to Pin the Navigation panel. You can also check the option Collapse the navigation pane on connection:
http://help.remotedesktopmanager.com/file_options_sessiontype_sessiontype.htm
Argg. That was it (checked collapse the nav pane on connect).
Thank you David.
