Inconsistency with default settings
I just noticed somewhat of an inconsistency in regards to default settings I think :)
I just set some default settings for a certificate entry, for instance i've selected the 'stored in database' and deselected 'Allow export' as default settings
When i do 'New Entry' and select Certificate then the settings i put as default are being shown. However if i then switch to another type of document, like a Microsoft Excel the settings for this type is also set to 'stored in database' and 'allow export' is deselected, this might be because i haven't set any default settings for Excel documents (however i would think it should change to the real default settings, and not to the settings of another document type).
Even worse is when i do a 'Add document', the 'Default' document is selected (with default settings), when i change it to 'Certificate', the default settings i set for the Certificate (like stored in database) arent applied, the settings of the first selected document type is used for all document types. This would mean that when i add a certifate via this way i get certificate entries that have the 'Allow export' setting selected.
All Comments (1)
This is a known limitation that we have. It's nearly impossible to apply the new default in the UI without loosing everything you entered (filename for example). However in the latest beta we changed the Add Document and all the other direct add to let you choose the type you want.
It no longer select Default by default.
