Document Container Path or Document Path Variable
Hi, all.
I would like to be able to define one or many Global Variable somewhere.
The example is following:
Our tech create a lot of sesion that are simple link to documents.
Those documents are in a sever in our network.
The problem is that if we want to change the server that has this documents we have to go one by one do edit the new path.
I have foung a work arround setting a custom variable but this one only affects to my installation.
and if I want to change others to have it has to be set one by one.
Sorry for my English!!
The idea of the container (not for us) is to be able to setup a directory in wicht all documents could be saved.
Then an option to backup that directory within the app.
Thanks.
Enrique Noceda
Spain
Do you mean the custom variable in File->Options?
Yes, that is the work arround I have found.
But this doesn't work globally.
It doesn't go into the database, so other users would have to setup them manually.
thank you
Enrique Noceda
Spain
I have entered a feature request and we will do our best to add in the next version.
