Problems while configuring more than 1 data source
I'm having troubles to configure more than one datasource in RDM.
As Adminitrator I want yo be able to configure 2 datasource.
-As a common user (previously added)
-As an Admin. (new one)
I have already configured the common user and want to add a new one as Admin.
I'm able to configure them I see them and I'm able to use them. But, in the restart the RDM I only will see the common user data source. The admin data source disapear.
All Comments (5)
It seems that your remotedesktopmanager.cfg file is not saved or it's flushed. It's usually saved in %LocalAppData%\Devolutions\RemoteDesktopManager
Where have you installed RDM?
Hi David,
That's right. Here is a screen shot where you can see it.
file
Could you try to install RDM in another folder than program files. For example in C:\RDM
Could you try to install RDM in C:\RDM and verify if the configuration can be saved?
