Questions concerning Telnet, SSH SHell, etc
Hey guys.
First off, LOVE YOUR SOFTWARE.
Now thats out of the way, I noticed a couple of things
1) When changing from "Telnet" to "SSH Shell" or otherwise, the port does not update on the right. Which means I have to wait for the program to fail to connect before i can go back in there and change it manually.
2) When telnet doesnt work, it locks up the entire program until it fails. Anyway around this?
on another note
3) I cant seem to drag and drop a dameware object into an RDP object (thereby making the dameware object a subconnection to the RDP object). Is there no way around this?
Thanks for the great work guys!
I have entered a bug request for the Telnet and SSH switch issue. For the freeze, it's not simple because it's linked to the UI and the third party. I will see what we can do.
The drag and drop to create sub-connection is not implemented. You can use the Refactoring to Parent/Unparent a connection.
Bug request and UI: awesome david thanks!
Parent/Unparent: Could you give me a quick description on how to do that?
Yes take a look at those topics:
http://help.remotedesktopmanager.com/refactoring_overview.htm
http://help.remotedesktopmanager.com/refactoring_subconnection.htm
