Error After Connection
After I connect to a client, and work a little (a dozen clicks at the most), I'm getting the following error: "Because of an error in data encryption, this session will end. Please try connecting to the remote computer again." It then throws me out.
This is a Cisco VPN client connection, and I have the VPN settings in the same session setup as the Microsoft RDP.
All Comments (1)
Did some goggling, and ended up uninstalling the Sonicwall VPN client off my machine. Problem solved.
Ends in 6 days
