BUG: Ping not working when RDP not on default port
if you set up a session like e.g. www.mysite.com:30000 ping won't work (DNS error).
Cheers,
allmdm
You can't ping a port as ping and TCP operate at different layers. mysite.com must be available if you want to ping it. The result will be the same with the Windows ping. I will try to find a solution but I can't promise.
thank you for your comments.
Devolutions inc.
Hi David,
of course it can't be a ping to that other tcp port.
IMHO it now tries to "ping mysite.com:port" instead of just "ping mysite.com"
Cheers!
allmdm
Doh !!!
sorry, I will fix it for the next release
David
