Problem with 6.6
Hi there;
I recently installed Version 6.6.0.0 and, because I'm working on a new computer, I password protected the program so that it cannot be opened randomly.
The problem that I'm having, at this point, is that every time I open the program, I get a reminder to install the UltrVNC Add-On. If I choose ignore, I will be able to carry on until the next reminder. If I choose install, I am asked to restart the program where-after I have to go through the same procedure over again.
When I go to "about" I can see that the Add-On is loaded. I have also done a manual installation of the add-on and this has not changed anything.
Any ideas? Is there a quick/registry fix for this?
Thanks.
Berold.
All Comments (1)
Just for a test, could you try the latest beta version. It's 6.9.5.
Ends in 5 days
