Smart Sizing - Full screen issue (Embedded RDP)
Hi, I am having an issue when setting any RDP session with the following Display settings:
Remote desktop size: Default
Smart Sizing: Checked
Fit Embedded RDP in Window: Tried both, not sure what this does actually.
The issue I am having is that the smart sizing does not scale up to my full screen settings. Instead, the resolution stays the same, and the screen becomes letterboxed. This used to work before version 6.0.0.0, but I noticed it stopped working when I upgraded. I saw a similar thread with the same issue which had no resolution:
http://forum.devolutions.net/forum/topic1024-fullscreen-mode-is-letterboxed.aspx
My config:
Standard Edition, Version 6.6.0.0
Windows 7 Enterprise, SP1, x32
Resolution: 1920 x 1080
All Comments (1)
I the problem with the smart sizing and the embedded mode is that the ActiveX does not scale up. In an old version the application ws using the screen resolution by default and now it's using the available container space. If you want to scale up to fullscreen, you could try to set the resolution to "Current screen size"
