Hi all,
starting with v6.5.0.0 I have faced the following problem.
I have a RDP Session with setting "Display" 1152x864.
When I try to use "Open Session (Fullscreen)" it does not work. It opens a window with Scrollbars.
I have that problem with all my Sessions.
It is still a problem wiht 6.6.0.0
I think it worked in the beginning with 6.5.0.0, but some day the problem started and is persistent.
The only way to get a session in Full Screen is to change the "Display" setting to "Fullscreen".
Windows 7 64 Bit SP1, RDP Version 6.1.7601
Many thanks in advance
Juergen
have you tried to uncheck the Fit to embedded window option?
Hi all,
The option is greyed out.
I use the Standard Edition
Select the Embedded mode to enable this option
Sorry, can you please explain a bit more detailed.
Maybe I misunderstood your initial problem. Do you have the problem in external mode or embedded mode? The embedded mode is when the session is opened nested in the application
in external mode.
The RDP session opens in a new window.
The problem is as described, that I can't get the window in "FullScreen" mode ("Open Session (Fullscreen)"), except I set that in the "Display" Tab.
So, in External Mode the Feature "Open Session (Fullscreen)" does not open the new window in "Fullscreen", but with the Settings in the "Display" Tab
Thank you for this bug report. I have found the problem and it's now fixed. This will be in the next beta release.
good to hear.
Is there a special Beta Download Area ?
Juergen
It's not released yet but I can send it to you. We have some work in progress so might see some screen unfinished.
