Right click on session, and want to cancel
So you right click on a session, then decide you don't need to do anything, so you want to cancel. There is no easy way to close the menu that's open. If you click outside of the menu, it should close it, IMHO.
All Comments (6)
When the menu is active and you press the Esc key, the menu should turn off.
That is not the case for me. Hitting escape sends that command to the open session.
Do you mean a right click in the RDP session directly?
Sorry for not being more clear. Right click on the session in the session list on the left.
But only when you have a session opened?
Okay - with NO sessions open, ESC will close the dialog window. With at least one session open, ESC goes to the open session, regardless of which session I have the dialog open for. "Disable close on Escape key pressed" is NOT checked in Options>User Interface>Keyboard>Navigation.
Closed
