Export - RDM not reacting
today i did an export
file -> export - all entries, check include credentials, w/o masterkey
file got written 03:58pm, rdm froze til 04:02, so i had to wait that long time,
2nd test gave me: file time 04:03, rdm freezes till 04:05
it's hard to wait that long if export is already finished.
rdm 9.2.4 @ NB (phys) w/ i5,8GB,256SSD,win8.1, 1gbit-lan
rdms 2.2.12 @ xeon dual, 6gb, win2k8r2, sql2012
systems are all far away from being maxed out
i started with /profiler, but that won't help because there are no timestamps logged, so you don't see the delay in log
Plz add Timestamps to Profiler!
Kind Regards
Markus
Hi
You are correct that we do not log system information during the export process, but we do log each entry being exported. In the usage log, do you see the timestamps near together or there is a pause somewhere?
[edit:exported/imported]
edited by mcote on 4/8/2014
Maurice
hi
sorry for my late reply, got ill.
usage log says that all entries get exported within a minute, no pause
Kind Regards
Markus
I have entered a enhancement request to optimize the export all process. I think that the delay is caused by the fact that RDM tries to find all the references for all the entries. However since we are exporting everything, this is unnecessary.
Ends in 11 days
