Dropbox frequent connection drops
Anybody else seeing frequent Dropbox errors?
All Comments (6)
What message do you get?
[6/6/2011 2:35 PM]ERROR System.InvalidOperationException: There is an error in XML document (1, 1). ---> System.Xml.XmlException: Data at the root level is invalid. Line 1, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlReader.MoveToContent()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderConnectionArray.Read83_ArrayOfConnection()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream)
at Devolutions.RemoteDesktopManager.Managers.SerializationManager.LoadObjectFromString(String str, Type type, Boolean createAnInstanceIfNotExists)
at Devolutions.RemoteDesktopManager.Business.DataSources.DropBoxConnectionDataSource.GetConnections()
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.LoadConnectionsFromDataSource(BaseConnectionDataSource connectionDataSource)
This means that the xml read is not valid. How often do you get that?
Usually not frequently. Today, about 20 times.
Outch,
It's very frequently, I will verify I can add an automatic retry.
Do you still having the problem frequently?
