Credentials not working for some users
I have a strange issue where I set credentials on a RDP session either directly on the object or inherited from folder. Credentials are working for others accessing the RDP object, but not for me. I'm administrator and others are a mix of admins and limited users.
We use PVM for credential storage.
This issue affects me on objects where I changes from one credential entry to another. Changes never apply. Again, for me only (what it seems).
Seen this issue since v8.something. We're currently on v9.1.4 and pvm v5.0.5. MS SQL as data source.
Please advice!
BR,
\ Andreas Stepan
All Comments (6)
Do you see your new version in View - Entry history? (requires an advanced data source)
Maurice
Yes, I have a <CredentialConnectionID> change in the history.
if you select the last two versions, the compare button will be active and you can see the changes.
What has been changed?
Maurice
<Stamp>
<UpdateDateTime>
edited by aste on 2/27/2014
since we see the CredentialConnectionID has changed, thats the link to the credential entry
Could it be that you had set user specific settings or local machine specific settings and these in fact override whatever you store in the session?
Maurice
Now i'm falling into blush mode. Of cause, it was user specific settings. So obvious. Thank you!
