RemoteApp problem
I've found that the RemoteApp feature with RDP is no longer working as expected.
I think it was working fine in the past, but in recent versions (9.0.16 at least) it starts with the full RDP interface instead of the remote App window.
It still works fine with RDP files opened by the TS Client and also it works inside RDM with a link to the RDP file.
But it does not work with RDP files opened by RDM and with every sessions configured in RDM.
I'm using Win 7 clients and Win 2008 R2 server.
Cheers,
Nico
Could you verify with the latest version to confirm the issue?
Could you export the .rdp file from RDM and check if it's different than the one that work?
I'm testing different versions and RDP files ... but it seems not an RDM problem.
Thank you,
Nico
