Single mouse click to make a connection
Hi
can some one help me in setting rdm to connect to a host by single click (not double click) on the host name (not the play button)
Thanks
Zuri
All Comments (2)
This is not support in RDM. I'm not sure if I can even implement this.
I understand,
but look at the major remote professional software logmein ignition teamviewer all have that as the only way to connect.
this is much easier way to work when you are a professional connecting many host's every day.
the best way is teamviewer way.
you hover with the mouse on the tree of folders auto opening each folder that you pause at, and when you click on a host the connection is made.
this is the ultimate professional way to deal with mass host's. isn't that the purpose of using a manager? making it easy.
Zuri
