Click and Drag not usefull in Session pane
Hi support,
When I am trying to move a folder using a Click and Drag in the "Session Pane" the Dashboard is blinking a long long time (sometime more than 2 minutes) but I am not patient enough and release the mouse button... Then the "moved folder" is moved haphazardly.
I am using version 6.1.0.0 and I have 539 sessions.
All Comments (1)
You are right, the Microsoft Tree view is ugly and it does not work well. It's already in the plan to change it. In the meantime, I will add a menu to move it. This will be in the next minor release.
