Cisco WLC Wireless LAN Controller
This login dialog looks like it is tied to windows itself. However I can not get RDM to populate the Username/Password. Any suggestions?
All Comments (9)
I might have an idea how to pass the password if it's really linked to Windows. Can you try to create a session tool and configure the credential for the tool? The reason is when you open a session tool, we set the credential in Windows, if you use the same IP for the tool, I think that it will set it for this one.
I am afraid I do not understand. I currently have a HTTP session Tool created. I have the credentials set. Problem is I do not know the element ID to use. I have tried using "Session Specific", "Credential repository", and "Embedded Credential entry".
Sorry for the delay, in the session configuration, go into the Tools tab page, enter your credential here and give it a try. This will preset the credential before opening the tool. I'm not sure that it this will work, but let's give it a try.
thank you
Hello, tried that and it still will not populate the fields. ANy other ideas?
Can you try a test for me, if this work, I might be able to find a solution, try in a browser something like this:
http://username:password@url
Replace the username, password and url by the value required for the cisco login.
This works with Firefox (two additional dialog boxes) but not with IE8 (Default Configuration).
If you have a possibility to try IE9 or Chrome, let me know
Can't do IE9 (Windows XP Box), Chrome works with the suggested solution.
Ok,
Thank you I will try to squeeze this feature for the next release
