Couple of minor issues with 6.0.1.0b
Since your last excellent support about the SonicWALL Global VPN client issues, I registered RDM and I have found some more minor issues:
- When viewing a connection, in the bottom right screen, when I select Logs, there is no scroll bar, so nothing can be viewed.
- When I click on open session vpn only, on a Microsoft vpn connection, credentials are asked. In the connection I have checked the Use credential repository. So I cannot connect automatically this way.
- Same thing, but then with SonicWALL Global VPN client, most of the time credentials are asked, but not allways. Again credentials are in the repository. When I use the same connection to connect automatically when a ping failes, both work without problems.
Finally, a stupid question. Is there any way to collapse all open connections?
Of course, al of these things can be because I didn't understand some options. If that's the case, sorry in advance!
Kind regards,
Ray
I don't understand for the scrollbar, I can see them (screenshot), maybe your screen is too small, can you send me a print screen? I will do some test for the credentials and come back to you as soon as possible.
For the collapse all, the option in the in Session Context menu (two last entries)
I have attached a screenshot, where you can see, no scroll bar. My screen has a resolution of 1366x768.
Kind regards,
Raymond
edited by Rayman on 4/26/2011
Thank you, I see what you mean, the scrollbar appear only the grid, so you have to resize it a little bit (grab the handle). I added a bug for that for the next version.
