logmein drag and drop not working
I use logmein frequently. A few times I have added logins to RDM (via drag and drop). Now today I was going to add the rest of my sessions after a few tests, but the feature no longer works in 6.0. So I just upgraded to 6.1 and same problem. Drag and drop gives "no symbol" and does not work. I am able to manually copy and paste the url link by manually adding the session and copy/paste the title, but I really liked the drag and drop feature. Is this a bug or am I just not doing it correctly?
All Comments (2)
This is not a broken feature, if you run your RDM application in administrator mode, it's not possible to drag it if the source process (IE) is in lower privilege mode. This is part of the new security model introduced in Windows Vista. What you can do, is run it without the administrator mode or just copy paste the url that you usually drag.
I tried to find a workaround, but I haven't succeed.
That is odd. It worked fine a few days ago (drag and drop) and with no changes that I know of, it now does not work. Could it have been one of those famous Microsoft updates?
