2 minor problems with SonicWALL Global VPN
I have just downloaded a test version 6.0.1.0. When I start a session with an embedded Global VPN connection from SonicWALL, I have noticed 2 minor issues:
- The minimum wait time for the VPN is 10 seconds, any lower value will result in reverting back to 10 seconds. The Global VPN connects within 3 seconds. I would love to be able to enter a lower value.
- When starting the SonicWALL Global VPN, I get a message: Closing SonicWall VPN connection... It is not closing but starting! This works fine for Microsoft VPN. It connects fine, it is only cosmetic.
Thank you for your time.
Kind regards,
Raymond
All Comments (9)
Sorry about those two bugs, can you try this version, they are fixed now:
http://remotedesktopmanager.com/download/Setup.RemoteDesktopManager.6.0.1.0a.exe
Wow!
That's quick! I was at a customer and couldn't react sooner. I have never seen a sooner reaction ever. I didn't even buy this (yet).
Anyway, both issues are resolved with this fix. Thank you very much!
Kind regards,
Raymond
It's not always like this, but we try to do our best :) Sometime, we don't have a stable enough version to do a quick fix (we are in the process of implementing a feature) but since we released an update yesterday, our code was fresh.
edited by dhervieux on 3/31/2011
This fix broke something else. When I'm connected with SonicWALL Global VPN and I do a ping it says now: No network connection detected. I can ping using command prompt. This did not happen on the regular 6.0.1.0.
Kind regards,
Raymond
Sorry about that, this was related to a test I did, so my code was not that clean finally, I uploaded the fixed version, same url
I downloaded again and installed, but still No network connection on ping...
Ok,
let's try with this version to be sure that there is no caching problem in the download:
http://remotedesktopmanager.com/download/Setup.RemoteDesktopManager.6.0.1.0b.exe
I just saw the problem, I uploaded the zip, not the setup, it's ok now
It's working super now, thank you very much again!
Kind regards,
Raymond Jansen
