Wrong Italian keyboard layout
Hi All
I have configured the Italian keyboard layout for a MS RDP session and on the remote server key "<>" is inverted with "\|". All other keys are properly corresponding.
I used the same configuration file with the RDM version for Windows and there's no problem of inverted key.
Kind regards
Andrea
All Comments (2)
Hi Andrea.
We are currently investigating this kind of problem with other kind of keyboard.
Thank you for your feedback
Benoît Sansregret
Latest version (0.9.49.0) has a fix for the keyboard
You can get it by clicking Check for Updates
Thank you
Benoît Sansregret
