We have remote desktop manager latest version running. Connection to vcenter 5.1 works fine but if we try to connect to a vmware machine it says "unable to connect to the MKS: internal error". Please advise.
J.
Hi
It all points to an internal error of VMWare, there are many results when you google that msg.
Do it perform the same way when you try to connect with a RDP session launched form the Microsoft Client?
Maurice
Yes, I did Google but results are unclear, therefore this post.
What do you mean? How would rdp be related in a vmware console connection?
Bottomline is that I would like to know what the prereqs are to make it work. My colleague had a thorough search and found out that apparently version 5.0 of the plugin is needed (and 5.1 does not work?) but still then when you connect it asks for the vmware player. The question then is if you really need this vmware player (doesn't seem logic to me).
