Screen Focus and Send ctrl + alt + del
After opening a session from a saved entry on the side bar, it would be great if the focus would shift from that side bar to the actual RDP window. This is especially noticeable when you make an RDP connection to a machine that doesn't already have credentials cached.
Additionally, an icon/menu option to "Send ctrl + alt + del" would be greatly appreciated. I realize fn + ctrl + alt + delete on the mac sends the command, but this would make certain cases easier.
Thanks!
All Comments (1)
Your issue are duly noted.
We will address them as soon as possible
Thank you for your feed back
Benoît Sansregret
