Keep folders collapsed or expanded
The problem I'm having with the folders is that I keep all folders collapsed so I can get to the right one without having to scroll all over the place but when I edit or add a new entry ALL folders automatically expand. I then have to go and collapse them again. Is it possible to keep the folder on their current state (collapsed or expanded)?
I second that very annoying behavior. On top of that, it keeps scrolling back to the top every time a change is made or a connection is established/disconnected. Very counter-productive.
edited by ekred on 11/6/2013
A new version is available with the tree state fixed.
You can now "Check for Updates" to try it
Thank you
Benoît Sansregret
I want to confirm that the folder state fix is in and working as I would expect it. Folders that are expand remain that way even after I close (command+q) and re-open the app. Good work guys, thank you very much
