Document / Guide
nb5
Disabled
Hi, could you possibly put up a quick idiots guide to using the SDK to get me started? I've had a look but my limited vbscript knowledge didn't get me very far. I need to get a plug in written for a simple program (Mochasoft TN5250) that uses command line switches for the options so it shouldn't be difficult. I've already set up connections for the program using the command line type, but the problem I have now is I've persuaded the boss to get the enterprise version so we can use a shared SQL db, and some of us are on 32bit and some on 64bit laptops so the default installation path is different. Any help would be appreciated, thanks.
All Comments (1)
We are working a tutorial for writing AddOn, this should be available this week. The best thing you can do is to download the source code of the SQL Management Studio AddOn. It's only calling a command line with some parameters.
Closed
