Problem of Password Storage for RDP Host Login
When saving multiple RDP host connection information locally, the password saved for each host will be changed to that of the last added host.
All Comments (1)
Thank you for reporting this.
To find out why the passwords are being replaced, could you send us the following:
  • The version of Remote Desktop Manager for Android you are using, and your Android version and device model.
  • How you add each host: do you create a new entry each time, duplicate an existing entry, or use another method? Please describe the steps.
  • A screenshot of the credentials section of one affected entry in edit mode, so we can see where its password is stored. Please hide the password itself. (I will send you a DM where you can upload this screenshot)
  • When the password changes: right after you save the new host, or only later when you open or connect to the older entries?
With this information, we can check whether the entries share one credential or whether this is a problem when saving.
Thank you in advance!
