Physical keyboard and mouse capture has not way to disable.
A fix for this issue has been implemented in version 2026.3.1.3
I'm using Samsung Dex with physical keyboard and mouse in remote desktop manager.
Remote keyboard and mouse capture works great! But there seems to be no key combinations to temporarily disable this feature.
The preferred behavior is when I use a specific keyboard combination (Ctrl + Alt+ Shift + Z like moonlight), the mouse capture behavior can be temporarily disabled. In this way I can use physical keyboard on other apps.
The use case is that Samsung Dex works on a seperate monitor (non-touch). Without this feature, I cannot use physical keyboard temporaily for other apps.
All Comments (4)
Thank you for reporting this. We will create a feature request to add a keyboard shortcut that allows you to disable this feature. We will get back to you as soon as possible.
Frederick Simard
Thank you for your patience while our team looked into the issue you reported.
I'm happy to let you know that the latest version of Remote Desktop Manager for Android (2026.3.1.3) includes a fix for this problem.
Please note that this version is being released gradually (phased rollout), so it may not be displayed in Google Play right away. As soon as you see the new version available, please install it.
Once you have installed the update, could you please test it in your environment and confirm that everything now works as expected? If the issue persists or if you notice anything unusual related to the same original problem, just reply to this message with a few details, and we will be glad to look into it further.
Maxim Robert
The shortcut to toggle it on and off should be Ctrl+Alt+Shift+Z.
Frederick Simard
Thanks. Just got the update. It works great.
