RDM with DVLS slow to load vaults
Not sure on the best place to give this feedback but my initial test of this 2026.3 install with a Devolutions Server backend is feeling very sluggish when swapping vaults when compared to 2026.2. Currently our large 2026.2 vaults take approximately 2 seconds to swap while on this version of 2026.3 I am seeing 5+ seconds to make the same swap.
We are currently aware of a few different performance issues with Devolutions Server that we're currently working on for the full 2026.3 release.
I'd still like to ask for a performance profiling log from you to help us validate whether the sluggishness you're encountering is the same thing we're currently addressing, or if it's caused by something different.
You can look at our help topic on performance profiling in auto-mode here: https://docs.devolutions.net/rdm/ribbon-menu-bar/help/performance-profiling#auto-mode
In short, simply open the performance profiler (Help > Performance profiling), stay in the performance tab and ensure the "auto-mode" is checked. Keeping this window opened, you can perform the actions that are slow, and it should output logs in the window. At that point you can send the log trace to our support or send it to me in private messages, so we can analyze it.
Thanks Hubert. I have created a profile and sent it through to support with this Forum post linked.
I can confirm we received it, I'll forward this to the devs and we'll address this as soon as we can.
