HTTP-Endpoint starting, even when its not configured in appsettings.json (Version 2026.2.0)
Hello PSU-community,
i belive that i found an bug with http/https-Endpoints in the current version (2026.2.0) of PowerShell Universal. I ll start with a short description of my enviroment. I got one virtuell server with two instances of PowerShell Universal running. They are installed as an side-by-side-installation (installation was done with the provided ZIP-file) with seperate repository-, log- and other folderpaths.
When i rebootet the server one of the two PSU-instances wasnt available, even though the services were running. When i checked the logs i got an tcp-port-conflict on port 60370 as an HTTP-Endoint. After restarting the service again the second instance became available, but besides the configured HTTPS-endpoint there was also an HTTP-endpoint (now on port 60371) running, which is not configured in the appsettings.json.
I provided the censored appsettings.json in the attachments for both PSU-instances.
I belive i get the port-conflict, because both instances (and there coresponding and manually created windows services) are starting at the same time and then try to reserve the same port. As a temporary workaround I also could prevet the opening dynamic HTTP-endpoint with port 60370/60371 by configuring HTTP-endpoints in the appsettings.json with differnt ports.
Please have a look into this and let me know if you need additional information.
Thanks in advance for the help.
Markus
appsettings_instance2.json
appsettings_instance1.json
@markusburkhardt Hey Markus. This has to do with the Devolutions login callback functionality. It does seem like a timing issue where both services are selecting the same port and then trying to bind to it. We select a port in the range, starting with 60370, and increasing from there to find an open port within the range. If two PSU instances start at the exact same time, a conflict could happen.
You can also work around this by specifying the PSULoginPort value in appsettings.json.
Here is some more information about it.
Licensing | PowerShell Universal
That said, I've opened an issue to track this because we should both be more resilient and also allow for disabling the port all together.
Adam Driscoll
@Adam Driscoll
Hello Adam,
first of all, thanks for the quick response and the great explanation. I took your solution approach and changed my appsettings.json for both instances accordingly. My port-conflict on server startup ist now resolved. One thing i noticed is though that the callback-ports for the Devolutions login are not running on the loopback address 127.0.0.1 or its IPv6-equivalent ::1. Is this behavior intended? I checked that with the following command (you may need to change the filter in the "where"-clause).
Get-NetTCPConnection -State Listen | Select-Object @{name = 'Server'; expression = { $env:ComputerName } }, LocalAddress, LocalPort, OwningProcess, @{name = 'Commandline'; expression = { (Get-Process -Id $_.OwningProcess).Commandline } } | Where-Object {$_.CommandLine -like "D:\*"} | Format-Table
Thats the output from my server. Port 60370 and 60371 are the configured "PSULoginPort"-ports.
Server LocalAddress LocalPort OwningProcess Commandline ------ ------------ --------- ------------- ----------- S107123 :: 60371 4028 D:\psu_test\app\Universal.Server.exe S107123 :: 60370 4016 D:\psu_prod\app\Universal.Server.exe S107123 ::1 49882 4028 D:\psu_test\app\Universal.Server.exe S107123 ::1 49812 4028 D:\psu_test\app\Universal.Server.exe S107123 ::1 49810 4016 D:\psu_prod\app\Universal.Server.exe S107123 :: 8443 4028 D:\psu_test\app\Universal.Server.exe S107123 :: 443 4016 D:\psu_prod\app\Universal.Server.exe S107123 127.0.0.1 49882 4028 D:\psu_test\app\Universal.Server.exe S107123 127.0.0.1 49812 4028 D:\psu_test\app\Universal.Server.exe S107123 127.0.0.1 49810 4016 D:\psu_prod\app\Universal.Server.exe
Since the callback-ports are not whitelisted in the Windows Firewall, they are not reachable from the clientside, and PSU works totally fine. Is it probably no issue in my use case, because we dont use the devolutions login?
Markus
@markusburkhardt It won't cause an issue in your case because you aren't using the Devolutions login. They aren't scoped to localhost to support hosting in a reverse proxy like Docker or IIS. If we were to do that, they would be inaccessible from outside the container and would fail to work. While we originally intended PSU Devolutions Login to only work on local machines, it was to restrictive to actually lock it down when it's very natural for someone to pull a Docker image and run a container in a development setting.
Adam Driscoll
@Adam Driscoll
Thanks for the clarification. I know understand the reason why you do it that way. I still have some security concern in my usecase, because its an open HTTP port which potentially can be an attack vector, if not properly protectet by a firewall. I whould prefer if you could disable it if you dont need it or configure it to use the already peresent HTTPS-Port.
On other applications in our infrstructure things like that where noticed negatively in security audits.
For now i am satisfied with the workaround and as you already mentioned maybe you ll take a look at this again in a future version of PSU.
Thanks again for the help and have a nice weekend!
Greats from Germany,
Markus.
