New-UDform -script. SSL connection could not be established
I’m trying to use the:
New-UDform -script in an app.
Here is the documentation I’ve used for reference:
New-UDForm -Id ‘form10’ -Script “Script1.ps1” -OutputType “Table”But I keep getting
An error occurred: Status(StatusCode=“Internal”, Detail=“Error starting gRPC call. HttpRequestException: The SSL connection could not be established, see inner exception. AuthenticationException: The remote certificate was rejected by the provided RemoteCertificateValidationCallback.”, DebugException=“System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.”)New-UDform does not have a -trustedCertificate para.
My Script1.ps1 is located in the Automation → Scripts
So, how does this work exactly and how do I get it to accept my cert?
try to make a connect-psuserver before using the New-UDForm.
Works for me (version 5.5.5)
What Security Mode do you have in your app settings?
Generally the gRPC error is because of a permission issue, if you have Strict mode, make sure that the user performing the action/visiting the page has permissions to Read the script in question.
Also if your script is in a folder, make sure you have the full path, not just the script name < this one tripped me up before with the Get-PSUScript cmdlet
Hi MS-Marox and insomniac
I’m also on Version 5.5.5
Here is the app I’ve tested with:
New-UDApp -Content {
## For scheduled jobs
$AppToken ='TOKEN'
#Connect-PSUServer -AppToken $AppToken -ComputerName 'https://myapp.domain.com' ## <- This also does not work.. But I'm pretty sure I had it working at some point.
Connect-PSUServer -AppToken $AppToken -ComputerName 'http://localhost:5000' ## This works
### Getting an overview of scripts, so that I can see the path ####
$Data = Get-PSUScript -TrustCertificate | Select-Object Name, Filename, relativePath, id ## <- Have to
$columns = @(
New-UDTableColumn -IncludeInExport -Property "Name" -Title "Name" -Id 'Name' -IncludeInSearch -showsort
New-UDTableColumn -IncludeInExport -Property "Id" -Title "Id" -Id 'Id' -showsort
New-UDTable -Columns $columns -Data $Data
#### This is the test I'm trying to get working
New-UDForm -Script 'Test.ps1' -OutputType Table
}I made sure to place my Test.ps1 in the root of automation. So there is no folder involved.
My App settings are pretty basic. I only remember adding https, so I’m not sure if it’s running in strict mode:
"Kestrel": {
"Endpoints": {
"HTTP": {
"Url": "http://*:5000"
"HTTPS": {
"URL": "https://*.443",
"Certificate": {
"Subject": "myapp.domain.com",
"Store": "My",
"Location": "LocalMachine",
"AllowInvalid": "true"
"Plugins": [
"SQLite"
"Data": {
"RepositoryPath": "%ProgramData%\\UniversalAutomation\\Repository",
"ConnectionString": "Data Source=%ProgramData%\\UniversalAutomation\\database.db"
}Some additional info: I’m running the app in a “custom” environment that points to pwsh.
I’m also using a service account on this custom environment to execute the job.
